Previous in Forum: Flushing Ring   Next in Forum: reply
Storage tank - floating roof
09/16/2008 12:56 AM
I need to change the Swing check valve on the tank roof drain system. Can anyone recommend where I can find such a swing check valve.
Good Answers: 101
Re: Storage tank - floating roof
09/16/2008 11:11 PM
Hardware stores or plumbing supply stores will usually stock them. Provide full specifications when placing your order to ensure you get what you want.
You might be interested in: Roof Curbs, Roof and Floor Trusses
