Hello, I have in my possession a plastic material that i need more of.It's approx 1/32 thick& black on one side, on the other side it has what appears to be a white fiberglass mesh with 1/10 th " squares. On top of this mesh is a clear plastic material. We are using this to eilminate friction between carbon steel (2"-14")piping and U bolts and the structure it is bolted to.This material is now 4" wide but i suspect it came/ got cut off a larger roll. It is pliable at 70 degrees.I beleive it would break continuity also but that is not the goal. Can anyone help?Mfg.,tele. ,contacts...
Thanks
