3/4" pipe lines with 24V pwr supply - I need basic 2WNC solenoid valve to process milk without the inevitable build of bacteria inside the valve - any suggestions would be welcomed.
I would look at GEA Tuchenhagen. I am assuming you need a 2 port valve and an actuator with a solenoid valve. I have worked with APV, Cherry Burrell, Sudmo, Scandi-Brew / Alfa Laval, etc. etc. The Alfa Laval "Think Tops" are way to finicky and will drive your controls people nuts. The APV valves I just find not robust enough and the control heads break easily. Cherry Burrell and Sudmo have there own set of issues. Also, if you want modules, panels or matrixes pre-fabbed, as well as some pro-bono engineering, Tuchenhagen, I find, is the most desirable. Now, chances are you will find that Tuch valves are on the higher end price wise, but when it comes to low acid applications, I do not like to fool around.
No, I am not affiliated in any way. It is just that my Tuchenhagen experiences have far outweigh any other valve manufacturer. And I have installed my share of valves. Check out the Stericom and Vesta line of valves.
