Previous in Forum: asking......   Next in Forum: CT's Connection in case of bus & transformer diff. ckt.
Power Supply from PT
09/22/2008 4:38 AM
Why should we not tap power supply from PT?
Re: Power Supply from PT
09/22/2008 7:37 AM
Dear Sir,
Primary Side of PT/CVT never shall be tapped. PT/CVT secondray voltage will be used used to differnt circuits. For metering, for protection. It shall from the respective core with relevant accuracy.
Regards,
N.Suresh
09/23/2008 12:38 AM
The question is about tapping power supply from the secondary of a PT for purposes other than metering and protection. Eg. 110V, AC supply is required in a 3.3kV switchboard for auxiliaries and whether it is advisable to tap power supply from the 3.3kV/110V PT (of adequate VA rating/burden) for the auxiliaries.
Regards,
09/23/2008 1:48 AM
Take a look at the KVA rating! That alone should (hopefully) give you a slight indication why not.
If that's not enough; what do you think will happen to your protection and metering if you load a PT? Think about that for a few seconds.
