Previous in Forum: Bright Spark   Next in Forum: Insulation Cable
8 comments
Cables Size
09/24/2008 11:41 AM
Can you let me know the cable size for
  • XLPE/SWA/LS/PVC
  • 11 kV
  • load to serve 5MVA
  • 1000 meters
  • 3-core
  • To be laid in underground normal soil
  • Also to be laid in PVC conduits.
Re: Cables Size
09/24/2008 7:48 PM
Why don't you try to make the calculations your self and we will assist you.
Re: Cables Size
09/25/2008 2:37 AM
use HT cable 4C x 250 sqmm,
Re: Cables Size
09/25/2008 4:08 AM
i have forget the formula to calculate, can you help by sending the formula for the calc
Engineering Fields - Power Engineering - Projects Engineer
Re: Cables Size
09/25/2008 9:49 AM
lenght of cable x VD in Ma X full load amperes . Devide by 1000 you will get the VD
maximum VD allowable is 4 % of the system voltage as per IEE regulations
You will need a cable capacity and Vd chart to calculate the above ,as the installation conditions ,operating temp. and type of cable are all considering factors
Please do this home work and then you will be guided,from where you have reached.
Regards
A wise person will understand more from a Foolish question than what a Fool will understand from a Wise Answer
Re: Cables Size
09/25/2008 10:30 AM
''length of cable x VD in Ma X full load amperes . Divide by 1000 you will get the VD"
Sak
I don't understand you formula. I am used to seeing
VD = amps x cable Z per 1000 ft x length /1000
Re: Cables Size
09/25/2008 8:46 PM
$$$$ = current multiply hrs multiply rate/hrs divide 1000
Re: Cables Size
09/25/2008 9:52 PM
"$$$$ = current multiply hrs multiply rate/hrs divide 1000"
WHAT?
Re: Cables Size
09/27/2008 1:41 AM
Wareangle
you have raised a very good question
Thats the formula we use when we have a IEE current capacity and VD chart at hand,to get the results directly from the pre-calculated chart.
We can know the Volt drop per amp per meter in mv for a given size of cable from the chart multiply by the I and total lenght of cable run than divide by 1000 to convert the result to Volts
Hope that is clear
Register to Reply 8 comments
Anonymous Poster (2); jiki (1); SAK (2); wareagle (3)
