Previous in Forum: II have about junction box and the nema 4x question   Next in Forum: Wiring Diagram
Torque
09/26/2008 6:37 AM
Can anyone help me: I currently have a test rig and I am trying to measure the torque on the crankshaft. I am looking to purchase a Transducer to fit inline between couplings. The problem I have is the Tools Steel shaft I have is hollow and I do not know the inside diameter. Without this I am only going to have an estimated torque value - strain accuracy would be accurate - ?
Can anyone advise as to my best course of action?
Many Thanks
United States - Member - Member Hobbies - DIY Welding - New Member
Good Answers: 50
Re: Torque
09/26/2008 11:39 PM
Can you give us a better explanation of what type of setup you are running; what are you testing?
Speak softly and carry a big stick.
Re: Torque
09/27/2008 2:48 AM
how about a Dynomometer?
Re: Torque
09/27/2008 3:10 AM
A local machine shop should be albe to measure it for you.
Re: Torque
09/27/2008 7:09 PM
I am not sure about your exact question, but it sounds like you want to measure torque from an engine crankshaft or perhaps an electric motor.
If you use a calibrated inline torque meter, the exact dimensions of the crankshaft, couplings or mating parts are not required in calculating torque. The inline torque meter transmits torque from one end to the other and is pre-calibrated at the facory. Seconday checks (with a torque arm/ calibrated weight set) during maintenance intervals assure accuracy. You may want to check this company's site: http://www.himmelstein.com/ .
Fans of Old Computers - PDP 11 - New Member
Location: In a mushroom field somewhere in Canada. Kept in the dark and fed sh--, well you know.
Re: Torque
09/29/2008 9:13 AM
Place a strain gauge on area of crankshaft that you are most worried about failing.
www.omega.ca good source for reasonably priced strain gauges and readouts.
Calculate torque from stress/strain values obtained.
Dirt is for vegetables. Pavement is for racing.
Good Answers: 53
Re: Torque
09/30/2008 12:37 PM
Why don't you use a simple rope pulley and weight method?
Re: Torque
09/30/2008 2:20 PM
thanks for all your input fellas, I think i have it nailed now.
Register to Reply 7 comments
awelch (1); Chazl (1); dadw5boys (1); rakesh_semwal (1); scott1977 (1); standarded (1); unclefastguy (1)
You might be interested in: Flexible Couplings, Fluid Couplings, Rigid Couplings
