Previous in Forum: Pressure Load   Next in Forum: High Bearing temperature
12 comments
Sizing of AHU Cooling Coil
09/27/2008 12:17 AM
what will be the cooling coil size for following details.
1) AHU capacity:- 12525CFM@125mmWG &
2) Cooling capacity is 58TR.(chilled water system)
if cooling coil velocity is 500fpm.
weather coil should be of 4 row or 6 row?.
if it is 4 row what are advantages?.
if it is 5 row what are all advantages?.
cooling coil should be designed for CFM or TR wise?.
Pathfinder Tags: Sizing of AHU Cooling Coil
Re: Sizing of AHU Cooling Coil
09/27/2008 6:24 PM
I hope this is some help - you have supplied no criteria for the coil - The fan and cooling are designed to meet a load - you seem to have the equipment before you have a known application.
There may be no stupid questions - Some are just poorly contrived !
09/29/2008 1:01 AM
THE COOLING COIL HAS RELATION SHIP TO AIRVELOCITY SO THAT THERE IS NO CONDENSATE CARRY OVER AND THE RELATION SHIP IS A SIMPLE CALCULATION.
CFM=12525 AND FACE AREA OF COIL IS CFM/VELOCITY= 12525/500= 25 SQFEET
HENCE THE SIZE CAN BE 5FEET*5FEET = SQUARE COIL( hEIGHT *LENGTH)
2.5FEET* 10FEET = RECTANGULAR COIL ( hEIGHT *LENGTH)
aS REGARDS CAPACITY USE THE FOLLOWING FORMULA
CAPACITY= 1.08*DELTA T(F)* CFM
NOW TR=58 SO IN BTU/H= 58*12000= 696000
SO 696000/12525CFM*1.08=DELTA T (F) =51.4
SO ITS RECOMENDED TO USE 6 OR EVEN 8 ROW COIL TO ACHIEVE THIS LOAD REQUIREMNT
HOPE THE ABOVE IS HELPFUL FOR YOU
REGARDS
RAJESH BALAKRISHNAN
DIRECTOR-ENGINEERING
STULZ-CHSPL (INDIA) PVT LTD
MUMBAI
09/29/2008 3:02 AM
Rajesh Sir,
Thank you.
This information is sufficient & more helpful to me.
Reagrds
Raju Anagdi
Bangalore
10/25/2011 4:37 AM
How you concuded for 6 or 8 row coil
09/23/2015 7:26 AM
HELLO SIR,
COULD YOU PLEASE SEND ME COIL SELECTION AND RELATED DOCUMENTS TO my email
address.*
I WANTED TO LEARN.
THANKS IN ADVANCE
*CR4 ADMIN - email address removed
From the CR4 Rules: Do not post phone numbers or email addresses. The CR4 Admin will delete all phone numbers and email addresses posted in threads or comments. You can share this information via the CR4 internal messaging system.
08/16/2016 3:21 AM
Sir,Thanks For information ,Pl clarify me for how much temperature difference how many rows of coil to be select.
for Chilled water system & DX System.
02/27/2020 1:50 PM
Hello RajeshSir,
Can you please show me how you came up with 6 row ? I want to learn.
Thanks
Umang
Anonymous Poster #2
05/10/2020 2:09 AM
Dear Sir,
Wouldn't the 'Total Heat Transfer Area' be necessary to determine the number of rows.
Total area would further depend upon the fin spacing, type of fin (wavy or straight), tube pitch (both vertical and horizontal), tube size (3/8", 1/2", etc.).
Since the question was related to the number of rows specifically, above data is necessary with the coil specification, unless these details are standardized.
Moreover, number of circuits will also be necessary to be specified to make the selection complete.
Would like to know your feedback.
Thanks
05/13/2009 8:18 AM
As the row deep increases the air & cooling coil contact increase reducing the bypass air, obviously the more Row Deep the less is the bypass factor.
CFM/500 will give cross sectional area of the cooling coil. Here it is 25.05 Sqft.
Go for 6RowDeep cooling coil, as 5RD won't be manufactured and also not standard practice for 5RD.
09/23/2015 7:24 AM
when we use 3,4,6 and 8 row coils?? and their selection??
can you please breif me??
thanks in advance
04/19/2020 5:45 PM
Hi,
Thanks for your reply. But by increasing the number of rows you are increasing the pressure drop for AHU blower. isn't it?
04/20/2020 5:09 AM
Amazing
Register to Reply 12 comments
Anonymous Poster (3); azmath (1); philroth (1); Rajesh Balakrishnan (1); rajuas100 (1); terala naveen (1); udoshi3599 (2); user-deleted-786 (1); vemuri.murli (1)
