Hi all:
I am into computer field hence I am little bit confused about this mechanical problem.
Actually I have to write a program for the following case.
I have rectanguler plate of 3 by 3 inch and am appliing uniform ressure load on it.Then I took 4 by 4 inch plate and applied same pressure(10PSI).The reaction force and stress on both were diffrent.
How is it possible because the laod is 10 lbs for one inch square in both the cases.
Is it because the total load(pressure *area) on both is different beause area is different ?
Thanks all
