I have a trailer which has a fixed load of 3900 lbs mounted such that much of the weight is behind the axle. The axel is 38" from the rear end and 112" from the hitch. There is only 100 lbs of weight on the hitch. As I can not move the load, I would like to move the axle back to get 700 lbs on the hitch. (600 additional) How far should the axle be back from the hitch?
