Previous in Forum: Eyewitness Accounts and Scientific Observation   Next in Forum: Unsubscribe
Determining Load Force While Towing
09/30/2008 4:35 PM
How do i determine the load force while towing. Is there a formula. example. If i had a tractor towing an airplane with a cable how do i determine the load force on the cable if the aircraft weight is 65000lbs towing on a level surface.
Good Answers: 21
Re: Determining Load Force While Towing
09/30/2008 5:13 PM
I would say your problem here is knowing the resistance of whatever you are towing.
Using F=ma you can see that the force would be zero if you are towing at constant velocity in ideal conditions. ie no frictional losses etc.
The tyres, bearings etc are gonna cause frictional losses and these are individual to each situation.
What shape is the trailer (or airplane)? Wind resistance depends not only on the shape but also what speed you are towing it at.
Maybe there is a general rool of thumb but I don't know one.
Good Answers: 123
09/30/2008 11:00 PM
You are right on the resistance issue. The only thing that I can think of that comes to mind is the tow hitch numbers. The tow hitch should carry 10% of the trailer's weight. But the pulling load must be higher than that. If the hill were steep enough, or there was a wheel stop against the trailer wheel, you could have to pull the entire weight of the trailer.
Bob
10/01/2008 4:05 PM
"How do i determine the load force while towing."
A load cell or something similar would eliminate all doubt and be closer to the truth.
bob c (1); MACA (1); Stirling Stan (1)
