Previous in Forum: Testing as per IS codes   Next in Forum: COSMOSworks, SolidWorks 2006, and Windows Vista
Steam Cleaning and Split-Unit Air Conditioners
10/08/2008 1:29 AM
I have heard is available on the market a "steam cleaning" equipment that can be attached to the evaporator coil of a split unit air-conditioner, to clean it , substituting the typical "chemical wash". Is anybody able to indicate where I might find such equipment?
Thank You
Re: Steam Cleaning and Split-Unit Air Conditioners
10/17/2008 3:37 AM
I have never found anything of its kind.
Please note the attached coil instructions fron one manufacturer.
Maintenance
Coil Cleaning
Coils should be kept clean to maintain maximum performance. For operation at it's highest efficiency, the coil should be cleaned often during periods of high cooling demand or when dirty conditions prevail. Power should be disconnected and locked out and motors should be covered to insure that no moisture penetrates into the windings causing motor failure if applicable.
Remove large debris from the coils and straighten fins before cleaning.
Clean refrigerant coils with cold water and detergent or with one of the commercially available chemical coil cleaners. Rinse coils thoroughly after cleaning.
CAUTION: Do not clean the coil with hot water or steam. The use of hot water or steam as a refrigerant coil-cleaning agent will cause high pressure inside the coil tubing and subsequent damage to the coil.
CAUTION: Do not use acidic chemical coil cleaners. Do not use alkaline chemical coil cleaners that, after mixing, have a ph value greater than 8.5 without also using an aluminum corrosion inhibitor in the cleaning solution. Failure to follow these guidelines or the manufacturer's instructions for use of cleaning chemicals could result in damage to the unit.
WARNING: SOME CHEMICAL COIL-CLEANING COMPOUNDS ARE CAUSTIC, AS WELL AS TOXIC. USE THESE SUBSTANCES ONLY IN ACCORDANCE WITH THE MANUFACTURER'S INSTRUCTIONS. FAILURE TO DO SO COULD RESULT IN SERIOUS INJURY, DEATH OR EQUIPMENT DAMAGE.
Fin Straightening
Coil fins may have been bent during shipping or servicing, and should be straightened to maintain maximum heat transfer. Reduction of the effective coil surface will correspondingly reduce coil capacity. Always check fin appearance after any handling of the coil and after any servicing is done near the coils.
Fin combs are sized according to number of fins per inch of the coil. For relatively small bends that require only minor repair, other tools may be used to evenly space the fins. Be careful not to damage the coils.
There may be no stupid questions - Some are just poorly contrived !
10/21/2008 12:45 AM
Thank you
10/28/2025 6:49 AM
I’ve come across similar questions before regarding the use of steam cleaning for split-unit air conditioners, and it’s good that you’re researching before trying it. Steam cleaning can be effective for removing surface dust and mild grime, but it’s generally not recommended for the evaporator coil itself due to the risk of high internal pressure and possible coil damage, as mentioned above.
A safer and more reliable option is to use a professional service that employs eco-friendly cleaning methods specifically designed for split units. Companies such as SoCool offer specialized maintenance services where the evaporator coil and blower components are deep-cleaned without causing harm to the unit. Their approach ensures efficient cooling and better indoor air quality while extending the lifespan of the AC system. You can learn more about how they handle coil cleaning and maintenance through safe, tested techniques.
In short, while steam cleaning tools may seem convenient, it’s best to rely on methods or services that are built around the technical limits of your air conditioner. That way, you maintain both performance and safety.
Register to Reply 3 comments
Anonymous Poster (1); henryross (1); philroth (1)
