Previous in Forum: NDT for Piping   Next in Forum: Hydroelectronic Governors
13 comments
Fuel Tank Calibration
10/09/2008 5:13 AM
Hey there, i need to caliberate fuel tank for my work place,which has been caliberated before but with enough errors.Horizontal tanks at 3.8 degrees tilt,2887mm diameter and 12,811 in length.Holding 81,000 litres,
The second tank is 80,000litres, 2,887mm diameter, 12,373mm length.How do i caliberated with with minimum error?
Schikampa
Re: Fuel Tank caliberation
10/09/2008 7:37 AM
hi chimi, volume in litres for a horizontal cylindrical tank = l{[r^2*acos((r-h)/r)]-[sqrt(2rh-h^2)*(r-h)]}/10^3 where l - length in cm r - radius in cm h - present dip level in cm (in first case for full tank it is 288.7cm) I monitor my daily fuel consumption using the above formula but my tank is with zero tilt. I also have made a excel worksheet with this formula and would share if you give your email id. I find this fairly accurate. Good luck, kayems.
10/10/2008 5:25 AM
Hi Kayems,thanks for your mail on the fuel tank caliberation,i would like to see how you monitor your daily fuel consumption on an exel worksheet.My email is sydneychikampa@yahoo.com.
06/15/2009 6:16 AM
Hi Kaymes
I tried your formula and i compare with Autocad
but is is nor matching please forword me the excel sheet on my email :
rajenderadula@gmail.com
06/18/2009 3:09 AM
Hi Kayems, read your response with much interest, just joind my coy as an engineer and tis 1 of my 1st assignments. got CR4 thru google! can i have a view of your excel worksheet? we have about 3 diff diesel tanks; 40,000ltres, 33,000ltres and a 15,000ltres, nedd to calib all them.
tanx and look 4wd to your ressponae... aanidu@uacdairies.com, tonyanidu@yahoo.com
03/13/2010 11:01 PM
hi kayem, can you furnish me a copy of your excel worksheet of this calibration formula, this formula would be helpful to in monitoring the day to day consumption of fuel industry with accurate calibration. kindly email to misfitz_twenty3@yahoo.com. Thank You Very Much. Michael.
03/23/2010 9:04 AM
send me the sheet , at jig12750@gmail.com
thanks
11/15/2010 6:40 AM
Hi Kayems, read your response with much interest, got CR4 thru google! can i have a view of your excel worksheet? we have about 2 diff diesel tanks; 30,000ltres, 12,000ltres need to calibrate the same.
Thanks and look forwaard to your ressponae... packiyanathan1.r@tcs.com
12/23/2010 11:08 AM
Hello Kayems,
I am trying to calibrate a Horizontal Jet A1 Fuel tank. It has x ammount of tilting as well. Please email me your Excell worksheet in order for me to figure out my tank calibration. I would really appreciate it. Thanks a lot. email: julianduarte.aerofull@gmail.com
Julian.
Good Answers: 15
10/09/2008 8:13 AM
You could have somebody do a 3D model.
They would need the inside diameter and the inside length.
It would be easy for them to put a 3.8 degree tilt on it.
Then they could figure out the volume at specified heights.
Maybe an hours work.
downhill slide to 112 (damn memor.)
Re: Fuel Tank Calibration
10/10/2008 11:53 AM
First full grief the car tank used to supply the tank whose volume is desired to calibrate. To unload the liquid until the mark of gauging that it has or in its defect to place one previously marks arbitrary to have a reference. To determine the density of the fluid referring it to a temperature of reference (20° C, 15° C, or another one). To weigh the car tank after the unloading. The difference in weight divided between the density corresponds to the volume of the fluid until the mark of gauging (or reference) in liters to the temperature of reference, of course, that are due to handle the values in the suitable units.
10/15/2008 2:44 AM
Fuel Tanks are calibrated by manually filling up the fuel tank using small standard containers of known volume and at the same time taking note of the corresponding liquid level.
11/09/2008 11:09 PM
If your tank is horizontal, read http://www.iso.org/iso/iso_catalogue/catalogue_tc/catalogue_detail.htm?csnumber=35926
(ISO 12917-1)
it the tank is vertical: http://www.iso.org/iso/iso_catalogue/catalogue_tc/catalogue_detail.htm?csnumber=37004
(ISO7507-1:2003)
11/12/2008 10:01 AM
need to take temperature into account because thermal expansion and contraction of 80,000 liters is going to mess up the fluid level.
in aerospace we always want to know pound mass (lbm) and not gallons or liters
make graphic cuts (from Catia/Unigraphics/Solidworks...) of the tank and get volume versus height
from fluid type get thermal expansion coefficient
measure fluid temperatue in tank get fluid density
from above you should be able to calculate actual volume & lbm
Register to Reply 13 comments
Anonymous Poster (8); ddk (1); fgarcia (1); julianduarte (1); kayems (1); om=entendimiento (1)
You might be interested in: Fuel Cells, Fuel Testers, Fuel Dispensing Equipment
