Previous in Forum: Steel I-Beam Requirements   Next in Forum: Voltage Drop
14 comments
tower wind load calculation
10/11/2008 6:00 AM
I am trying to calculate the wind load on a 20m transmission tower but could not lay my hand any formulas. Can anyone help me on this? Can someone show me a section of BS8100 that explained wind load calculation of space frame?
George.
Good Answers: 137
Re: tower wind load calculation
10/13/2008 4:00 AM
Hello guest
If you're just trying to get a safe ballpark estimate, velocity pressure in Pa = 0.5*ρ*V2, where ρ = air density, 1.2 kg/m3, V = wind speed m/s. Multiply by the projected area of each member for the force. The full calculation gives factors less than 1 for shape of members, so above is on high side.
I assume you know how to use above to work out total bending moment at tower base, which is usually what's needed.
Appropriate wind speed depends on location but for normal purposes in UK I use 50 m/s (= 112 mph)
Cheers.......Codey
10/26/2008 3:26 PM
Codey,
Thanks for your information, but my problem is not how to calculate the wind pressure. My problem is the area at which the wind pressure is acting. Is there any factor to be used to multiply the overall projected area of the tower to get the bending moment of the space frame?
George.
Good Answers: 137
10/27/2008 4:47 AM
Hello Guest
No, I don't think so, as the BM depends on the height of each member, and the distribution of member areas and heights isn't constant in general (though for a particular style of tower it might be possible to come up with a formula).
Also I'm not familiar with BS8100. I have an old (1972) copy of CP3 : Chapter V : Part 2 which covers this (I don't know what the other Chapters and Parts cover). I assume this has been superseded by BS8100. CP3 is pretty heavy going, sounds like you need to get stuck into BS8100 to find what you're after. Good luck!
Cheers..........Codey
10/28/2008 5:39 AM
Codey,
Thank you for your help. I can use projected hieght and area of each member, though I am thniking that there might be an easyer way to go about it. I have a copy of CP3, but it did not see any thing about wind load on space frames in the code.I understand from a journal that BS8100 covers this.
Thanks,
George.
Good Answers: 137
10/28/2008 5:59 AM
George
Had another look at CP3 and sections 8.3 to 8.5 cover frames. Is this applicable to your problem? From a quick perusal it only seems to give forces, not moments, so as your tower probably tapers towards the top you still have some work to do.
Sections 8.2.1 and 8.2.2 give forces on individual members for a different approach, needing rather more work.
Cheers.......Codey
02/11/2009 3:08 AM
Moderator note: This comment was deleted because it contains a personal email. Per CR4 Rules, please refrain from posting personal email addresses or phone numbers.
03/31/2009 9:11 AM
Hello.
Wind Load calculation is with BS6399-2 "Wind Loads" and not with BS8110. Wind pressure calculation is clearly shown on BS6399 with respect to all particular criteria that your structure might require. ASCE Wind Load calculation is more comprehensive but carries similarities.
Anyway, back when I was designing communication tower it is always better to make an excel spreadsheet to calculate the wind pressure because it will vary according to the elevation. At the same time you can add columns on this spreadsheet for the member area, I mean the surface area of your proposed members (angle, double angle, I-Section, Circular Section, and alike). This area is impotant in determining the wind pressure distribution on the tower, specifically on the members. What comes next will be analysis using a particular software, in my case, STAAD.
It is important to remember that the main frame is moment stiff and the webs are not. The type of antenna that the communication will carry will also succeptible to huge amount of wind load.
That's all I can recall right now and I hope that it helped you a bit.
Good day...
03/31/2009 9:23 AM
12/15/2010 2:18 AM
Hi,
This is ullasan, i was trying to provide wind load on the structure(Via STAAD) but I am not able to finish it. if you can help me please. also as you said can send me some reference for this.
Ullasan.
11/04/2009 5:21 AM
01/04/2011 4:27 AM
dear fellow
to determine wind loads on towers ,u must follow the requirement of the EIA/TIA 222F SPECIFICATIONS.
1-ADOPT A WIND SPEED ACOORDING TO REGION
1-CALCULATE CALCULATE SOLIDITY RATIO
3 CALCULATE GUST RESPONSE FACTOR
4 CALCULATE STRUCTURE FORCE COEFICIENTS
5 CALCULATE WIND PRESSURE
6 CALCULATE WIND LOADS
7 ADOPT LOAD COMBINATION AS FOLLOWS
7-A D.L +W.L
7-B D.L+W.L+ICE LOAD
8-MAKE THE ANALYSIS THE DESIGN ACCORDING TO THE SAME STANDARDS
IF YOU NEED HELPS CONTACT ME
ENGINEER FAYEZ MOUNAYER -SYRIA
02/28/2011 4:18 AM
07/08/2020 8:28 PM
Dear colleagues,
I need guidance on the calculation of wind load on communication towers.
1. As the surface area reduces from bottom-up, do I consider pressure load per panel, by multiplying the trapezoidal area with the wind speed, or I will convert to a concentrated load at the surface nodes?
2. My dissertation is on the uplift capacity of transmission towers with case studies of communication tower foundations in my country.
3. A guide on how to apply the wind load manually will be appreciated so I can create a spreadsheet for it.
07/08/2020 11:09 PM
Anonymous Poster (4); Codemaster (3); Fareed Siddique (2); magd (1); Mohammed Fareeduddin (1); Severious (1); siTE (1); SolarEagle (1)
