Previous in Forum: telecom   Next in Forum: Confusion of IR Transmission LED
serial port
10/11/2008 11:48 AM
what is the output voltage and current produced by the serial com port of the pc?
Indonesia - Member - Member from Indonesia Hobbies - Fishing - New Member Engineering Fields - Electrical Engineering - Member
Re: serial port
10/11/2008 2:27 PM
Voltage sent over the pins can be in one of two states, On or Off. On (binary value "1") means that the pin is transmitting a signal between -3 and -25 volts, while Off (binary value "0") means that it is transmitting a signal between +3 and +25 volts...
http://computer.howstuffworks.com/serial-port2.htm
The electrical specifications of the serial port is contained in the EIA (Electronics Industry Association) RS232C standard. It states many parameters such as -
1. A "Space" (logic 0) will be between +3 and +25 Volts.
2. A "Mark" (Logic 1) will be between -3 and -25 Volts.
3. The region between +3 and -3 volts is undefined.
4. An open circuit voltage should never exceed 25 volts. (In Reference to GND)
5. A short circuit current should not exceed 500mA. The driver should be able to handle this without damage. (Take note of this one!)
http://www.beyondlogic.org/serial/serial.htm#1
Fear of God is the beginning of knowledge, God bless you.
Reply to Forum Thread
