Previous in Forum: Unequal Load Sharing Between Parallel Gens.   Next in Forum: Electricity consumption
About Yaskawa Speed control unit
10/15/2008 1:12 AM
Hi, I'm working at automotiv industiries. We are using 1200T stamping machine. The main motor is AC type. Speed control unit is Yaskawa CIMR G7A4090. Can I use the machine with out speed control unit?
Re: About Yaskawa Speed control unit
10/15/2008 2:35 AM
of cause you can !! if you dont mind efficency, power dissipation and precision.
you hve to change your fuse either to prevent its broken every time you start motor.
--I wonder why you put out such foolish issue?
10/16/2008 1:33 AM
cnpower said
"you hve to change your fuse either to prevent its broken every time you start motor."
W R O N G A N S W E R
10/16/2008 4:40 AM
wow, why?
reason?
