Previous in Forum: Analysis on Air Compressor   Next in Forum: Identify a Part of Grain Dryer
Chilled water coil temperature
10/15/2008 10:32 AM
Chilled water coil temperature details ...
As for chilled water coil,
1) One is the air in & out temperature (Wet bulb/Dry Bulb) of passing coil?.
2) water in/out temperature for cooling coil?.
Engineering Fields - Agricultural Engineering - Agricultural Mechanization Technical Fields - Technical Writing - Translator Technical Fields - Education - Fluid Power Uruguay - Member - Born and raised.
Re: Chilled water coil temperature
10/15/2008 11:33 AM
Excuse me. Which is the question here?
I am happy.
10/15/2008 9:00 PM
Do you want to chill water or air? Any idea of geometry, working pressures, flow, what's it for? What exactly are you trying to do? It's not possible to say with your words.
Humm... suspicious you are...
Register to Reply 2 comments
