Previous in Forum: CURRENT INJECTION TEST   Next in Forum: Auto Vs Power Transformer
Serious problem: 3 to 1 phase transformer? hepl me
10/16/2008 6:34 AM
Dear everybody!
your problem is also mine. I am working with Siemens' locomotive. On this system have an special transformer. 3 cables input for 3 synchorous phase but output is just 2 cables for only one phase. This is vector group for ours: Delta for primary windings and V for secondary winding.
Who can explain me how does it work? Please show me its diagram
thanks a lot.
Pathfinder Tags: 3 to 1 phases transformer
Re: Serious problem: 3 to 1 phase transformer? hepl me
10/16/2008 7:19 AM
This is so called scott transformer. pls search this cr4 or google for detail.
3 to 2 or 1
10/16/2008 7:41 AM
I understand what u mean. But could u show me diagram: 3 to 1 phase transformer
10/16/2008 7:47 AM
Im afraid I cannt find it in my computer now. I forget where I put it.
I try and show you if I find it.
10/16/2008 7:51 AM
thanks very much. If u find, please show me. Very important for me.
10/20/2008 12:05 AM
I sent the photo to your mailbox. pls check.
10/16/2008 9:00 AM
hi,
i saw something same used to supply basler PRP210 reverse power relay and its called three phase to single phase matching transformer. thats all what i know about it but i cant tell you how does it work?
i was going to ask this question!!!
thanks
01/14/2009 8:27 PM
This sounds like a "ZIG ZAG" connection where two secondary phases are connected reverse polarity with the third phase. In a three phase delta network the instantaneous sum of the voltages is zero (Otherwise the network would be a big short circuit).
Therefore the instantaneous voltage of any two phases equals the voltage of the other phase, and the result will appear to be a single phase. This circuit is used often to use three phase generators (Alternators for you purists) as single phase power source.
Consider the "ZIG ZAG" of two phase secondaries as 2/3 of a Wye network connected in series with the third phase. The connection between the "ZIG ZAG" of two phases and the third phase would show the same voltages as a single phase center tapped transformer.
Any Help[???? CEKM
Register to Reply 7 comments
Anonymous Poster (1); cnpower (3); Nguyen.Siemens (2)
