Anyone with "hands on" engineering experience with wound rotor motor modernizations needed.
I recently installed a roll forming machine; circa 1950's and attempted to "upgrade" the controls via VFD and braking resistor.
Everything appeared to work ok until approaching full torque requirements (120" x 2-3/4" boiler plate) at which point the main motor "stalls" under load. ?!?!?!?
Question is: Am I attempting the impossible? What (if any) is the most efficient way to get this system functioning properly?
The motor is a 200 HP Westinghouse rated for 257A, 440.
The drive is a 250 HP Allen Bradley 1336E rated well above the motor's requirements.
Shunting the rotor leads and applying the VFD to the "T" leads has worked well for me in past applications. Guess I should have taken that scholarship to MIT. (not really)
Regards to all...
