Previous in Forum: Attittude control   Next in Forum: How to calculate the pressure in Kg/cm2 of the 5 " RF feeder cable with length ?
3.5 tons
10/18/2008 10:38 PM
GREETINGS,
HOW DO YOU CONVERT 3.5 TON A/C UNIT INTO WATTS FOR A LOAD CALCULATION.
WILL
Re: 3.5 tons
10/19/2008 1:34 AM
Hi,
Basically, you can only convert ton to Killowatt cooling capacity and this cannot be use in electrical calculatio. What most HVAC designers do is to get a catalogue/ technical brochures and select an available units then from their you can see the Electrical Power input required by the Unit.
If you have more questions that you think I can help, please email me to my email address below because I have not internet connections at my office.
bennegregsiman@yahoo.com
bsiman@meinhardt.com
Note: Always CC both emails.
Hope you somehow find this in order.
Regards,
Benn Siman
Please check my Biography
Good Answers: 143
Re: 3.5 tons
10/19/2008 7:07 AM
Three rules:
1. Don't type in all caps; it's considered impolite.
2. Use this calculator
http://www.unitconversion.org/power/watts-to-tons-refrigeration-conversion.html
3. Remember that this tells you the heat load not the electrical power required; the electrical power requires a knowledge of the efficiency of the unit under operating conditions.
