Previous in Forum: New Septic, Nasty Smell   Next in Forum: Cracked Tie Rod for 2600-Ton Press
balancing primary variable chilled water system
10/20/2008 10:15 AM
Primary variable chilled water flow; I wanted to ask is there a procedure or a technical experience of some colleagues regarding on how to balance a primary variable flow in a chilled water system. regards
Tu conoceras la Verdad y la Verdad te hará Libre......Jesus
Good Answers: 101
Re: balancing primary variable chilled water system
10/20/2008 11:20 AM
It's normally done using a pump that can exceed the maximum pressure/flow requirements of the system by approximately 20-25%. An inverter, a variable speed device, will control the pump so that it can supply flow/pressure as required by the system.
10/24/2008 6:12 PM
I understand and I have the systems to provide that but if there is any guideline to do the balancing??
regards
Good Answers: 101
11/02/2008 10:05 AM
Based upon the clients' requirements for minimum and maximum water velocity in the pipe.
Register to Reply 3 comments
