Previous in Forum: MDEA Properties   Next in Forum: Oil Water Interface
18 comments
Need Connector
10/20/2008 6:51 PM
I am in the need of a connector, that looks somewhat like this,
It allows you to connect wires easily to a row of pins.
I have a 50 pin double row array.
I need to only go 5 rows wide to be able to connect to the pins I need to connect to.
Anyone help with someone that makes these things?
Joe
Re: Need Connector
10/20/2008 7:04 PM
This page from RS Components lists lots of things like your picture. You should be able to narrow it down initially by connector pitch. Don't have to buy them from RS, but it may give you a lead to the manufacturer, & thence to a local supplier.
Re: Need Connector
10/21/2008 2:12 AM
Hello Joe,
Where are you based? I've got bucket loads!
Re: Need Connector
10/21/2008 9:29 AM
Southwest Wisconsin!
How about you?
Joe
Re: Need Connector
10/21/2008 3:33 PM
South of Spain! Johns got the right idea!
Location: The cigarette-stained drunkard living in the cardboard box outside Marks & Sparks delivery entrance, Eastgate Shopping Centre, Basildon.
Re: Need Connector
10/21/2008 3:12 AM
I don't stock them. Try Dodgy Dave in Vange. He might have some <Cough>.
Essex jobs for Essex yobs! <Burp>.
Re: Need Connector
10/22/2008 3:15 AM
Re: Need Connector
10/22/2008 7:08 AM
Re: Need Connector
10/22/2008 4:10 AM
Have a look at WAGO or PHOENIX, they`ll lead you to their disties.
I`m sure your picture is one of their products.
Regards Uwe
The sum of intelligence on earth is a constant. And the population grows and grows and .....
Hobbies - CNC - New Member Hobbies - Musician - New Member
Re: Need Connector
10/22/2008 4:16 AM
Looks like a "Phoenix contact" part. Suggest browse their website for a distributor.
Think and move like an electron
United Kingdom - Member - New Member Engineering Fields - Transportation Engineering - New Member Technical Fields - Marketing/Advertising - New Member Hobbies - Target Shooting - New Member
Re: Need Connector
10/22/2008 5:09 AM
As others have said it looks like a Phoenix connector or equivalent which are widely used and readily available. There are several variations with different pin spacing so be sure to check this. The 5mm range is the commonest in audio-visual equipment.
Re: Need Connector
10/22/2008 6:04 AM
In the Farnell book 1, Pages 1603 to 1606 they are listed under IMO, CAMDEN (and even Weidmuller, different colour but they will fit). The RS book 2 also shows IMI, Weiland, Wago and Phoenix 5.08 connectors which looks the same so you are spoiled for choice.
Be carefull to measure the pin spacing as they come in 2 pitch sizes, 5.08 and 7.5mm. Your picture looks like a 5.08.
Re: Need Connector
10/22/2008 2:20 PM
These are manufactured by 'Phoenix', Germany.
If you are based in India, major cities like Delhi, Mumbai, Bangalore, Calcutta have
their representatives.
Best Luck
United States - Member - Member Engineering Fields - Manufacturing Engineering - Member Hobbies - Fishing - Member
Re: Need Connector
10/22/2008 2:25 PM
Yes, it is a WAGO connector - we use them all the time with various pin counts.
http://www.connex-electronics.com/?url=/html/products/wago_main_select.html&kw=google{Wago{wago&gclid=CK7Ho766u5YCFRJexwodczFfmQ
That should get you started.
"Stepping up to the plate" is not enough, you have to swing to get a hit!
Re: Need Connector
10/22/2008 2:28 PM
Ooops - it is a phoenix - my apologies...
http://www.phoenixcontact.com/pcb-connection/32102_29557.htm
Here you go.
Re: Need Connector
10/22/2008 10:04 PM
That connector is called a 'phoenix' connector. You might try Newark or Mouser.
Re: Need Connector
10/24/2008 2:10 AM
This a Phoenix Connector.
Can be purchased from RS (Radio Spares), Farnell, form Phoenix direct,
In the US from Allied. See page 288 to 300 or
1 800 433 5700 or WWW.alliedelec.com
Or Newark 1 800 4 NEWARK or www.newarkinone.com
I hope this helps
Shocking from OZ
Re: Need Connector
11/01/2011 5:16 AM
Dear Joe,
This connector is what we called terminal block.It is a very common product.If you still have demand.You can just let me know.And then I can send you some samples.
Best regards!
David
It is not easy to meet each in such a big world.
Re: Need Connector
11/01/2011 6:44 AM
Hope NSS hasn't been holding his breath for the last 3 years (see the date on which he started the thread) ...
Register to Reply 18 comments
Anonymous Poster (1); ashokmkarnad (1); Camilliontwo1 (2); Chankley (1); dadw5boys (2); JohnDG (2); madness (1); Mr. Truman Brain (2); nap (1); NSS (1); Stinky Pete (1); tom (1); uweka (1); Virlaymon (1)
