Dear CR4 Denizens,
You often see piezo tweeters shown as having power ratings like 75 W or 400 W or something in this range. Piezo tweeters typically have a max input voltage of around 25 VRMS or so. What makes these power ratings seem a bit optimistic (to say the least) is that piezo tweeters have a very high input impedance. A piezo tweeter looks to the amplifier much like a capacitor in the 0.1 μF to 0.8 μF range, more or less. Look at the capacitive reactance over the tweeter's frequency range of, say, 5 kHz to 27 kHz. It ain't 8 ohms, I can tell you!
The combination of high impedance and a typical max voltage of 25 VRMS forestalls any power dissipation figure much more than several hundred mW at most and certainly not something in the 75-400 W range.
So, with that long preamble in hand, here's my question: Are these power ratings referred to an 8-ohm load? If so, why aren't tweeters rated by input voltage rather than input power? 75 W into an 8-ohm load works out to be about 25 VRMS across the load. The power ratings make sense if an implied 8-ohm load in parallel with the tweeter is the configuration the ratings assume.
(Note: A piezo tweeter dissipating 75-400 watts directly is ludicrous. Even assuming a very efficient tweeter - say, 90% of the input energy is converted to sound - the remaining power is converted into waste heat that has nowhere to go. Think of how hot one of those tiny 7½-watt soldering irons get. Now put all that heat inside a small plastic cavity and see what happens. No piezo tweeter even comes close to 90% efficient; we'd have a meltdown in milliseconds.)
No, those power ratings must be referred to some implied load. It's the only way they make any sense. So, is an 8-ohm load the typical reference impedance when spec'ing tweeter input power?
Comments, suggestions (and money) warmly appreciated!
