Previous in Forum: electrical besic   Next in Forum: Name That Diode
can u solve(emf)
10/22/2008 7:52 AM
hi,
tell me emf is the factor of source or ac motor.
Engineering Fields - Power Engineering - Projects Engineer
Re: can u solve(emf)
10/22/2008 8:05 AM
emf= Electro Motive Force-- and is generated at the source,it builds up the P.D. if that answers your question.?
you need to elaborate more .
A wise person will understand more from a Foolish question than what a Fool will understand from a Wise Answer
10/23/2008 1:34 AM
hi, sak
u said emf is generated at the source, ok think we have motor connected across source and voltmeter. so we supplied the supply to motor our voltmeter will show some voltage, now if we remove the supply what will read by voltmeter will it come to zero immediately or gradually. if gradually then it means emf is supply by motor?....
10/23/2008 2:21 AM
Yes-Due to megnetic remenance ,take any electrical motor and connect a volt meter across the terminal and rotate the motor ,there will be some voltage readings on the meter,a similar effect is used in power generators(on start up) but the voltage is then build -up and controlled by AVR and excitor coils.
There is also the back emf which will bring down the voltage gradually to a certain level
Remember the motor coils are inductors and store some power.
Good Answers: 53
10/23/2008 3:15 PM
So what if it comes down slowly? That happens due to the stored energy by inductor. Just like in the case of a capacitor connected to a battery.
Capacitor is charged by battery not that battery is charged by capacitor.
Good Answers: 53
10/23/2008 3:22 PM
Now think this way.
Remove your motor and battery from one other and take a voltmeter, measure the voltage on both terminals of both the items.
And record the result where do you get the emf? On motor or on battery?
Anonymous Poster (1); rakesh_semwal (2); SAK (2)
You might be interested in: EMF Meters, AC Motor Drives, DC to AC Converter Chips
