Previous in Forum: Engineering Project Help Please!! Need Creative Minds!!   Next in Forum: V Belt ( B-34 ) Getting damaged frequently
M.S."C"-Class Pipe - Piping-water Flow & Pressure?.
10/23/2008 4:21 AM
I reqd to maintain 2 kg/Sq.Cm in the pipe coneected with 4mm of 25 Nozzles.
1) what will be reqd.lfow in the pipe -?. in US GPM
2) What will be the pipe size ?.
3) what will be the pump capacity?.water tank is at 5mtr level.
Re: M.S."C"-Class Pipe - Piping-water Flow & Pressure?.
10/23/2008 1:49 PM
I don't really understand your situation.
Are you injecting water into the pipe? Or are the nozzles the outlet of the pipe?
Are you pumping from the tank or into the tank?
What length of pipe do you need?
Please explain a little more what you are trying to accomplish.
10/24/2008 12:55 AM
Sir,
yes i has to inject water into nozzles thru pipe with pressure of 2 Kg/Sq.cm.
Tank is at 5mtr level and water has to be pump thru pipe & at end of different location nozzles are fitted.
when water is pumping thru pipe, in that 2 Kg/sq.cm to be maintained.
pipe length is upto 5mtr from tank to nozzle end.
I am pumping water from tank to end of 5mtr level where i kept some clothes & by that pressure water it will be cleaned.(it acts like JACUZZI-showerbath).
for the above i reqd. answers.
1) what will be reqd.flow in the pipe -?. in US GPM
3) what will be the pump capacity and pump head?.water tank is at 5mtr level.
Register to Reply 2 comments
