Previous in Forum: facbricate an encloser that can with stand for 1000 degrees of celsius and wate   Next in Forum: Calculating RPM of Drive Pinion Gear on Yaw Mechanism to Acheive Yawrate
Water Flow and Pipe Pressure
10/24/2008 12:56 AM
Sir,
yes i has to inject water into nozzles thru pipe with pressure of 2 Kg/Sq.cm.
Tank is at 5mtr level and water has to be pump thru pipe & at end of different location nozzles are fitted.
when water is pumping thru pipe, in that 2 Kg/sq.cm to be maintained.
pipe length is upto 5mtr from tank to nozzle end.
I am pumping water from tank to end of 5mtr level where i kept some clothes & by that pressure water it will be cleaned.(it acts like JACUZZI-showerbath).
for the above i reqd. answers.
I reqd to maintain 2 kg/Sq.Cm in the pipe coneected with 4mm of 25 Nozzles.
1) what will be reqd.flow in the pipe -?. in US GPM
2) What will be the pipe size ?.
3) what will be the pump capacity and pump head?.water tank is at 5mtr level.
Pathfinder Tags: pressure in pipe?. Water flow
Good Answers: 16
Re: Water Flow and Pipe Pressure
10/25/2008 8:48 AM
Did I misunderstand or are you planning to wash your clothes this way?
Wouldn't it be more efficient to purchase a washing machine???? You will;
  1. Use much less water
  2. Have cleaner clothes
