Previous in Forum: can u solve(T/F)   Next in Forum: Replacing DC Motors with AC Motors
Genaration and Transmission
10/24/2008 3:13 AM
Could any one please explain as to how to work out the follwings through simple calculations (thumb-rules) :
1) Kwh generation of 1 MW Power Plant - (What PLF (Plant Load Factor) along with the average hours per day operation of the Plant should normally be considered for the purpose)
2) Transmission Voltage to evacuate the genearted power in Point 1) above (i.e. what should be ideal KVA of the transmission line to tramsmit this generated power over a distance of 100 KM for example and how do we decide that?)
Regards
Good Answers: 103
Re: Genaration and Transmission
10/25/2008 1:44 AM
The Plant Load factor is very difficult to predict - We have plants with Load factors as high as 90+ to the ones with PLF less that 60%
It all depends on the plant machinery reliability, maintainability, conditi, load pattern (whether the energy generated can be evacuated) etc.
PLF is calculated over a time period (monthly, annual etc) and are not instantaneous. No thumb rule for this.
Other part is -
generated units = 1000 x 24 x MW x PLF x no of days(PLF calc duration) units.
For transmission - KVA
Take average PF = 0.8 and you get
1MW/0.8 MVA = 1.25 MVA
- you have to design the transmission line on full capacity and not on PLFs
the KV is for you to decide based on the grid voltage, and other economics, lower voltage = more line loss, more copper in lines.
Higher Voltage = More transformer (step up, step down) and insulation costs
Thumb rule may not apply. But all designs is on the generation capacity and not on PLF. We design the generation capacity on PLF so that customer get un interrupted supply.
10/25/2008 2:59 AM
Thanks Sb for the valuable inputs. It's a great help.
Regards
