I want to reduce the pressure in a water pipe by using orifice, but with a single orifice plate I will get cavitation. The fraction
where
I know that the cavitation problem can be solved by using three successive plates, but I do not have room for tree plates with flanges and sufficient distance. From articles I have red I understand that cavitation created by an orifice will result in cavitation on the orifice plate and not on the surrounding pipes. Is this assumption right? If this is correct I have been thinking on the possibility to use only one orifice plate, and exchange the plate when the restriction gets to low.
Is this a possible solution?
Are there anyone who have some good literature to recommend on this subject, I would be glad to know.
