Hello friends.
Here is a practical problem we are facing with the ABS moulded part shown in below picture,Thickness of part is 1/4inch.
Red arrow shown is feed position, if you watch the picture carefully there are very fine weld-lines in the direction of material flow at right side of each hole.to my understanding reason is very obvious that material flows from both side of each punch and got welded at some point.
the question is how to solve this problem.Material can not be changed.
Help requested.
Thanks in adavance.
