Previous in Forum: forces   Next in Forum: TDS & Microseimens
sucking up a spill
10/26/2008 8:10 AM
How much Polymer crystals would be necessary to hold 400ml. of fluid ?
I have not failed. I've just found 10,000 ways that won't work.
Pathfinder Tags: polymer crystals
Re: sucking up a spill
10/26/2008 8:52 AM
I don't think there's enough information here. Have you looked at a vendor website such as Lab Safety Supply's?
It can sometimes get TOO interesting,,,
Good Answers: 68
10/26/2008 11:10 PM
Hello Topper,
What is the spill? If it is not a hazard and the spill seems very small, why worry about the amount and or perhaps cost?
If however, as was the case at a print place I worked for a short while, a machine continuously leaks. You can buy various sizes of 'tube' shaped or snake like absorbent 'dams which can be used to prevent oil and other liquids from creeping from under a machine and thus be hazardous. These look exactly the same as the 'snakes' used at the base of a door to keep draughts out. They are also available in other shapes , pillows etc, and once they are finished with, depending on what has been absorbed, they can be replaced with more of the same or just disposed of appropriately.
http://www.directindustry.com/industrial-manufacturer/absorbent-74639.html
This site makes the 'socks' we used and other items.
10/27/2008 9:14 AM
If we were using a fluid such as distilled water the amount would be around 1/2 teaspoon.
Faith is not blind, it is supremely reasonable.
10/27/2008 9:32 AM
Welcome aboard! What fluid did you have in mind? Polymer "crystals" will not always be the best choice.
Register to Reply 4 comments
babybear (1); EnviroMan (1); HouseSheep (1); TeslaFan (1)
