Hi all,
I am installing a vacuum gauge between a 3 way valve with dual fuel filters and a lift pump. There are numerous nipples and elbows required and all are 1/4". Brass fuel elbows, are squared on the outside and from what I can see of the inside seem to be of a more severe turn and not as smooth as their general plumbing, red brass elbow cousins. Does anyone know if the flow resistance is different between the two of them and whether it is significant? I wouldn't want to place any additional loads on the lift pump. I could always up-size to 3/8" but that just means more money, weight, and bulkier the install.
What are your thoughts?
My second question is whether the access port and its little tube on the bottom of the vacuum gauge is meant to be occupied by fuel oil or air? Does it matter?
I wouldn't install the gauge upside down but during installation it might come to have fuel inside the piping and then be inadvertently lifted upside down allowing fuel into the access port of the gauge. Would this be a bad thing? I would assume that during a normal vertical install this wouldn't happen and air that is inside the port would remain there keeping fuel from coming into direct contact with the sensor. I realize that fuel is reasonably un-compressible where as air would decompress and compress as the lift pump does its thing possibly affecting its readings or not.
What do you think?
