Previous in Forum: what is the ratio of cement, sand gravel for plasterin and founation and others   Next in Forum: Gravitational Acceleration
13 comments
Cutting Conduits in Trenches
10/27/2008 5:49 AM
I have been working on this problem in civil engineering. On occasion it is necessary to cut conduits in trenches when there are cables in them -either power or communication. The real challenge arrises when there are multiple conduits in the trench - for example 2 wide and 3 high. Using a wire file is not the answer as once through the conduit it will start cutting the cables inside. In the case of a single conduit one can cut the top of the pipe and suspend the cables on a piece of wire or string while cutting the bottom with a saw. Battery sabre saws are good for this. But the problem is when you are faced with a formation of 4 or more conduits often touching each other.
So far I have been sharpening the drive side of a toothless chain saw chain - the theory bieng that the cheek plates will stop the cutting tips penetrating the cable space. This works but is rough on the hands and inclined to bite in. I have welded odd links to stop them tipping up and biting in and can tell you that the leading side of the cutting piece needs to be welded and not the trailing side. I have also inverted part of the chain so that one can define which section of the pipe you wish to cut. [ The top, far side or the bottom.] On the middle section the teeth point outwards while you are cutting with the part near the handles. The exposed face one can deal with using a hand saw However I still do not have a user friendly tool even if it does work.
The conduits are of course PVC and vary form 40mm dia to 300mm the most common being 80 to 150mm. The conduits are required to have 600mm cover so one is working in the confines of a trench - not so easy.
Re: Cutting Conduits in Trenches
10/28/2008 12:19 AM
Seems like they would have a saw like the one used to cut cast of human arms or leggs for this.
Looks like there is room for a new invention here.
Good Answers: 97
10/28/2008 2:19 AM
Have you tried a small rotary saw blade (slitting saw) in a portable (cordless) die grinder? This form may provide greater control options because you may use blocks to limit cutting depth etc..
Or you could loop the chain saw chain around the conduit; you'd need a longer chain, and proceed to sever the conduit similar to the way pipe is cut with chain
10/28/2008 7:15 AM
I have tried that but because of the shape of the teeth on the chain it is very hard to keep engagement with the sprocket. When the teeth bite they jerk the chain violently. I am looking at having the tips of the teeth coated with diamonds on the curved side. This will eleiminate the "Biting". Unlike the wood plane there is no way to control the "bite". Not all steels can be coated. Its like playing snakes and ladders and the only way to get to the end is to keep on keeping on.
10/28/2008 8:26 AM
Why do you need to cut open a conduit in the trench anyway? Why not go back to the nearest connection boxes on either end of the area to be dissected, disconnect one end and pull the cables out the other end? It sounds awful risky to me the contained cables. Are you a burgler tryng to breach a security system?
Eschew obfuscation.
10/28/2008 8:40 AM
There is a chain you can adjust with a cutting egde on the inside of the wrench you turn around the PVC pipe and it cuts thru.
I have never used it but saw a city employees usiung one to cut thru water pipe to add a "T" for a new subdividion.
It looked just like a chain wrench but with the cutting edge on the inside. The edges of the chain act to limit to depth of the cut.
10/28/2008 9:20 AM
There are so many reasons not to do this...especially since these cables will be energized once the work is done. You did de-energize them first....right?
10/28/2008 10:50 AM
My solution to that problem:
Wrap around the conduit 16-14AWG nickel wire (heater wire) in a way that you can tighten it slowly through the cutting process, connected to a low voltage source, say 12V car battery through a 200 to 300W (or as calculated,) rheostat. Heat the wire carefully, to no more than 180-200ºC (It won't even turn red) by turning the rheostat from max "R" to min, and tightening the wire at the time. You really need two persons to do it safely... some practice required, so you know when to stop. It will go through the PVC like butter...
Take heed! the wire, at this length, is practically 0Ω, and forgetting to add the series resistance will cause the wire to fuse (at best...).
We call it "hot knife"...
Hope it helps.
Wangito.
Never trade luck for skill.
Good Answers: 97
10/28/2008 11:41 AM
One person can do if the wire ends are attached to a bow
10/28/2008 1:12 PM
When we run into this situation, we often just use a piece of construction string. The trick is to keep it moving, and move the cut around the conduit to avoid damaging the wires inside. Basically there is no single all useful solution to this problem, and it typically takes multiple approaches (scoring with a saw or knife, cutting with string, etc.) and good old fashioned elbow grease to get the job done.
10/29/2008 9:59 AM
Use your wire file like this:
When you have cut thru the conduit, slip a piece of curved sheet metal over the cut portion, to protect it from the file, and move it around the pipe as you cut.This will allow you to cut all the way around without injuring the wires inside.
HTRN
10/30/2008 4:50 PM
Field trick,
Use cotton string. You will go through a bit of string, but will not cut your cables.
Illegitimi non Carborundum.
10/31/2008 6:33 AM
Nice avatar <VBG>.
Eschew obfuscation.
10/31/2008 6:35 AM
Oh, I forgot; I like your witicism signature. It means, "Don't let the bastards grind you down" doesn't it?
Eschew obfuscation.
Anonymous Poster (2); bsf (1); bwire (2); dadw5boys (2); HollaIFyaHEMI (1); Kyoto (3); Lendog (1); wangito (1)
You might be interested in: Cutting Services
