Previous in Forum: Excel Ranking   Next in Forum: Visual Basic 2008 Express Edition
13 comments
Pakistan - Member - New Member Engineering Fields - Energy Engineering - New Member
XP compatible software to be installed on vista
10/27/2008 11:42 PM
Hi,
I want to install Siemens PLC software on my PC which has OS VISTA , but the software is compatible with only win98, 2000, xp. Is there any patch available which enables me to install the software on vista??
Pathfinder Tags: patches vista compatible XP
Re: XP compatible software to be installed on vista
10/28/2008 7:55 AM
Have you even tried it? It may work fine. If it does not work then being a little more specific on what does not work would help other people help you.
If software was created before the launch of Vista, that doesn't necessarily mean that it wont work on Vista. I'd say give it a try first, then go from there.
If you seem to have problems installing, then try running the installation in compatibility mode. To do this you will have to right click on your installation .exe (setup.exe probably). Then go to properties and click on the compatibility tab. Then check the box which says run in compatibility mode, choose windows xp. Then try installing again.
10/28/2008 10:54 PM
It probably depends on whether the software relies on a device driver. Usually these are different between Windows 98, 2000 and sometimes xp. I'd say though you will probably find that the software works just fine, especially if it supports xp. Best advice would be to try it.
10/29/2008 12:41 AM
As others have sugtgested. Try it! If it doesn't work get a new version from Siemens!!!
PSv
10/29/2008 7:44 AM
Your best bet, stay with XP. Vista = problems.
Wangito
Never trade luck for skill.
Good Answers: 11
10/29/2008 7:57 AM
I will second this thought. Unless you have a bloody good reason to want to switch to Vista then stick with XP.
Come to think of it, is there any reason to switch to Vista? I'm not sure it does any thing better or faster than XP, it just seems to have more crapware embedded.
Eric
Good Answers: 38
10/29/2008 8:19 AM
I bought a new computer with Vista installed for my daughter. Vista bites the big one. What really ticks me off is when they make updated software that won't work with the old systems, and old programs that won't run on the new systems. All they want is your money, not your loyalty. Wheres all this backward compatability they talk about?
The last fight was my fault. My wife asked "What's on the TV?" I said "Dust!"
10/29/2008 9:03 AM
Hi afifahasan,
I was only reading on this forum yesterday about a software package, supplied by microsoft (free download), which I believe will solve your problem. It's called Vitual PC 2007 and, it allows you to run all of the Windows versions of OS you mentioned (all at the same time if I'm not mistaken), as long as you've got the licenses for them. You can then run your Siemens software on whichever OS you decide to use. Try the link below and see if it will do the job.
http://www.microsoft.com/windows/products/winfamily/virtualpc/default.mspx
They've also got some software (also free), called Application Compatibility Toolkit Ver.5.0, which allows you to test run applications, to see if it's compatilbe with vista. If not, there is then a network that will try and work on a fix for you.
Regards,
Neil
10/29/2008 10:38 AM
Like others have said try it and see if it works. Depending on your version of Vista, there is an option called compatibility mode, it allows you to run software in Vista simulating Win95 up to XP. I run Vista Ultimate 32 bit version, and it has this option. I can't speak for the 64 bit version.
10/29/2008 11:13 AM
Vista will not support Siemens PLC software step7 , step5 microwin .
This is confirmed by siemens engineers and I had to Purchase a new laptop which supports XP.
Never never never give up
Good Answers: 97
10/29/2008 12:04 PM
Hi afifahasen,
As other posts have said try it and or go to Siemens PLC site and look for a patch for Vista; if you need it Siemens will have it or the path to it.
I have not experienced compatibility troubles with software running on Vista (blessed I am indeed) if it will run on 2000/XP. Earlier editions not having the patch update to 2000 do not generally run on XP/SP2 or Vista.
Good Answers: 97
10/29/2008 12:29 PM
10/29/2008 1:24 PM
Greetings,
I switched to Vista because of home LAN connectivity issues and really am not that impressed by it. However, there is a way to run older versions of Windows apps using the compatibility mode that can be found in the properties (that's a right-click) of the .exe file.
Check ouit this and similar sites http://www.howtogeek.com/howto/windows-vista/using-windows-vista-compatibility-mode/ they may give you the help you need.
Good luck
Good Answers: 97
10/30/2008 11:04 AM
A pre-beta form of Microsoft 7 the Vista replacement O/S has been leaked to Bit Torrent. Try googling Microsft 7
Register to Reply 13 comments
Anonymous Poster (3); bwire (3); ca1ic0cat (1); charsley99 (1); Graebeard (1); rimig88 (1); shooter (1); vijaygr (1); wangito (1)
