I don't know if this is already mentioned here but do keep in mind the maximum weight of the filtered material and choose the screen that can withstand that weight.I've seen a lot of screens failing under the weight of the substrate and rectifying the same obviously is very time consuming!
Also try using a covered screen if dust generation is high.
