Previous in Forum: cable jointing kit is needed for you..   Next in Forum: How to Reduce the Earthing Resistance
12 comments
electrical engineering
11/01/2008 7:00 AM
How do I calculate the power of motor required for pushing a main steel gate weighing around 2500Kgs.
Good Answers: 183
Re: electrical engineering
11/01/2008 8:15 AM
Not enough data to give an answer.
11/01/2008 10:29 AM
Depending on the construction of the gate, it's area and windage may be more significant than it's weight .
Good Answers: 53
Re:electrical engineering
11/01/2008 11:28 AM
Hello you need to provide at least details as---
1 horizontal or vertical displacement.
2 amount of displacement.
3 Frictional coefficients of bearings.
4 Time to open gate.
5 linier or angular type motion.
11/02/2008 12:25 AM
Mr.Rakesh,
horizontal displacement.
No bearing , gate is mounted on a grooved wheel.
less than one minute.
Linear type motion.
Good Answers: 53
11/02/2008 2:24 AM
Assuming you have done enough lubrication of your bearing system.
Lets assume coefficient of friction as 0.5 for calculation purpose
And total amount of displacement is 2meters.
Force required is =
2500Kg x 0.5= 1250 Kgf
Work done for the displacement of 2meter is =Kgf x Displacement
=1250 X 2= 2500 Jules is the total energy you need,
Now if you want do it in 60seconds?
Watt required = 2500/60=41.666 joules/seconds (watt)
Further you can factor in gear efficiency, Inertia, and any other losses.
11/02/2008 8:44 PM
mass = 2500kg, other parameters unknown (assumed).
To push up this mass, you need 2500kg x 9.8N/kg = 24500N
If you need to push up this mass for 3 meters, you need 24500N x 3 m = 73500J
If you need to work this in one minute, 73500 J : 60 sec = 1225W
1225W is absolute power to lift your gate to 3 meters in one minute.
The total efficiency is assumed as 0.3. So, you motor kW is 1225W : 0.3 = 4kW.
Akihito Shigeno @ JGC-Indonesia
Good Answers: 53
11/03/2008 4:05 AM
Hello,
As original post says 2500Kg is Weight ,So Gravitational acceleration of 9.8 already comes in picture, I mean weight of 2500KG is already equal to 2500KGF.
Second point is, since motions is horizontal, force required to push need to be multiplied by coefficient of friction.
Thanks and regards,
11/03/2008 4:19 AM
Your second point surely nullifies the first?
The gate isn't being lifted.
If friction can be minimised and time isn't an issue a few watts would do it!
Good Answers: 53
11/03/2008 4:41 AM
Yes,
Thats what my first post says too, just 42 watts are required if he wish to finish the task in one minute. and even the frictions coefficeinet is 0.5.
11/03/2008 5:50 AM
I revised my solution.
9.8kg/Newton is still required to convert kgf to Newton.
mass = 2500kg, Coefficient of friction is assumed as 0.5. Displacement is assumed as 2 meters.
To slide this mass, you need 2500kg x 0.5 = 1250kgf.
To convert kgf to Newton, 1250kgf x 9.8N/kgf = 12250N
you need to move this mass for 2 meters, you need 12250N x 2 m = 24500J
If you need to work this in one minute, 24500 J : 60 sec = 408W
408W is absolute power to move your gate to 2 meters in one minute.
The total efficiency including design margin is assumed as 0.3. So, your motor kW is 408W : 0.3 = 1361W.
So you need a 1.5kW or 2HP motor.
Regards
Good Answers: 53
11/03/2008 5:58 AM
Yes you are right. gravity will to come in picture.
Now its perfect answer.
Sometime two wrongs make things right.
11/04/2008 1:04 PM
you can push it with even a little 3V DC motor out of a childs toy if speed is of no concern...
Register to Reply 12 comments
Akihito Shigeno (2); Anonymous Poster (2); nick name (1); rakesh_semwal (5); user-deleted-1105 (2)
You might be interested in: Gate Valves, Gate Drive Transformers, Gate Drivers
