Previous in Forum: Basic Database   Next in Forum: Virus? HELP!
Visio4
11/03/2008 2:27 PM
Does anyone know of an upgrade, or patch, to cause Visio4 to operate under Windows Vista? I can load it in, but all I get on open is the opening picture. I cannot open Visio4 itself, or any file created in Visio4.
Popular Science - Biology - life lover Hobbies - Musician - music lover Safety - Hazmat - better safe than sorry United Arab Emirates - Member - desert trek Technical Fields - Procurement - procurement
Good Answers: 58
Re: Visio4
11/04/2008 2:49 AM
For Visio 2007, no patch is needed for it to work with Vista.
You can get the info at: http://www.csupomona.edu/~ehelp/software/vista_applications.html and also directly from the horse's mouth at http://www.microsoft.com/windows/products/winfamily/virtualpc/overview.mspx
HTH!
Now the darkness only stays the night-time, in the morning it will fade away. -- George Harrison (All Things Must Pass)
Re: Visio4
11/04/2008 7:11 AM
I didn't say Visio 2007 - I said Visio4.
Good Answers: 58
Re: Visio4
11/04/2008 7:35 AM
the short answer is: NO
if your usage of visio 4 is simply viewing and printing, you can use a viewer. otherwise, <sigh> you can just imagine how 2 pieces of software coming from the same company cannot work together and have to force you to upgrade or downgrade one or the other.
your choice.
Re: Visio4
11/04/2008 8:16 AM
Thanks - but by screwing around a lot, I finally got it to work. But not from the internal drive (managed by Vista), but directly from the CD in the external drive. I can now create, edit, view, etc Visio4 files. Took a while, but I finally got it. But then, I'm not too bright.
Good Answers: 58
Re: Visio4
11/04/2008 8:30 AM
you're onto something, man!
just how exactly did you do it? what do you mean "not from the internal drive, but directly from the CD in the external drive"?
I would suppose a Virtual PC would have done it, too, i.e., running an XP sandbox inside a Vista OS.
Re: Visio4
11/04/2008 8:39 AM
By digging around in the CD, I uncovered D:\VISIO\VISIO16.EXE & created a shortcut. But again, the original, purchased CD must be in the D drive. I cannot get it to work from the C drive. But, like I said, I'm not too bright.
Good Answers: 58
Re: Visio4
11/04/2008 8:56 AM
just as I thought. you ran the application from the CD drive.
good hack / workaround! it's probably running a little slower, but it works, at least!
Register to Reply 7 comments
