Radiography (using Gamma Rays) of Circumferential Weld of Two Thick
(125 mm) Forged Alloy Steel Cylinders of a Thermal Cracker using
Submerged Arc Welding (Narrow Gap), revealed porosity due to improper electrode composition.
The remedy is to remove the weld material and 1~2 mm of base metal
on both sides of the J-Narrow Groove and re-weld the entire
circumference with proper electrodes. Standard Post Weld Heat Treatment will be used to relieve the stresses.
HAS ANYBODY EXPERIENCED THIS, READ OR HEARD ABOUT IT?
Will the strength of this new joint be lesser? If yes, then what would be the percentage reduction? Will the life under thermal cycling also be reduced? If yes, then by what approximate amount?
