Previous in Forum: Swimming pool evaluation   Next in Forum: controling kva of maximum demand.
interposing VT in synchronising circuit
11/06/2008 7:34 AM
Hi,,,,,,,,
can anybody wil help for my below question ..............
the interposing VTs are used for incoming and running busses in synchronising scheme why these two VTs are used? what are advantages?
Re: interposing VT in synchronising circuit
11/06/2008 7:53 PM
may i know where is the location of this your project ? and what is kind of this project ? is it related to oil & gas project ? thanks
11/09/2008 3:47 AM
IVT is connected after pt is selected for incoming bus and running bus.
i.e incoming pt secondary then IVT primary and then the IVT sec is connected to synchronising meters and equipments ,the same is for running PT.
is it necessaryto have an IVT of same rating 1;1 ratio with 50 VA CL3P/0.5?
What is the problem in connecting these PTs directly to synchronising meters?what are the advantages in having these IVTS?
11/06/2008 8:48 PM
Dear All,
For proper answer, oneline diagram must be studied.
Generally, a synchronizing relay needs both VTs ( income and bus) have same voltage ratios and measuring same phases. If not same, you need interposing VT's to correct the differences.
Regards
Akihito Shigeno @ JGC-Indonesia
Akihito Shigeno (1); Anonymous Poster (1); elect-ok (1)
