because of envelope restricitions (resulting in high RPM to obtain the required flow), altitude requirements (5 psia at pump inlet), and 260F MIL-PRF-7808 fluid the gerotor pump is cavitating. the true vapor pressure of the fluid even at 260F is less than .01 psia. we must be creating something close to vacuum as the gerotor teeth opens to gulp in fluid.
will controlling the inlet flow (5 psia laminar) or (5 psia turbulent) make any difference? any tricks on shaping the georotor to prevent caviatation?
thanks
