Previous in Forum: mini projects   Next in Forum: Fire Extiguishing Systems
welding consumable
11/08/2008 3:07 AM
please guide me how to calculate the welding electrodes/filler wires for a pipe joint.
Re: welding consumable
11/08/2008 11:10 PM
  • The following site includes 3 samples of calculations methods for :
  • Cost Per Unit Method
  • Cost Per Length Method
  • Cost Per Weight Method
  • Determining the Cost of Welding
11/10/2008 5:10 AM
depending upon the pipe material u are using
Hobbies - DIY Welding - pipewelder
11/10/2008 8:40 AM
I am assuming that you are talking about cost? To figure this out I would need the Size and schedule of pipe and the type of electrode or welding you intend to use. What I try to do is calculate lbs. of electrode per inch of weld. Once I have a number per inch on each schedule then I just simply count the inches, do the math and add another 15% for stubs and wastage. I am sure there are many formulas that you could use but I have always relied more on the practical methods and have been ok with those so far. Also unless I know the science of how an answer is obtained I would be leery of the answer and would have to check it practicality before trusting it as well.
pipewelder
pipewelder
Register to Reply 3 comments
Abdel Halim Galala (1); Anonymous Poster (1); pipewelder (1)
You might be interested in: Welding Accessories, Welding Alloys
