Hi all,
I have DB1(3 phase which include single phase power in it) which consist of one elcb1 n DB2 with another elcb2, both DBs r located side by side with seperated 3 phase power supply, but sharing same neutral terminal n earth terminal connection. Recently, one of my colleague accidently touch one of the live wire to body(earth), which is part of DB1.
So, fr0m here we can see, if a live wire from DB1 touches the earth body, it should tripped elcb1, well it did tripped, but the problem was that @ DB2 elcb2 also tripped! This is making me confusing, i can see from both elcb has the same setting ie 1A, 0.25sec.
When i measured ohm thru its neutral line @ DB1 and DB2, both r using same neutral line, same goes to earth line point- means nothing wrong with it, right? But why does both elcb tripped instead of one?
PLZZZ HELP.
THKS :)
