Previous in Forum: Does power factor vary with load.   Next in Forum: American Disconnecting switches
APFC
11/11/2008 9:18 AM
Can anybody tell how automatic power factor correction is attained. Does anybody have a selection criterion of how much KVAR is needed or something like that??
Avoid plastic... LIve Green....Get automated..Try new things...don't forget basics...!!!
Pathfinder Tags: Power Factor
Re: APFC
11/11/2008 11:35 PM
This is a discussion forum.
The details you are asking for are easily available on the net. Try Google search.
In case you have a problem with regard to a solution for a practical situation elaborate the same for a response.
Atlas Shrugged - JGD
Re: APFC
11/11/2008 11:40 PM
Most of the power system loads are Inductive which results into flow of lagging reactive current in the system. This in turn burdents the transmission and distribution network. Ideal conditions for any power system is to have Unity power factor. Hence this lagging current is compensated by introducing leading reactive (capacitive) current which is done by connecting Power factor correction capacitors in the network.
The details of how much KVAR is required will depend upon the lagging PF of your load without compensation and the improvement in this PF that you are looking for. You can check websites of Capacitor manufacturers which gives the chart for various combinations.
Rajesh
Re: APFC
11/12/2008 6:48 AM
Hello Bharathsyam,
Welcome to the forum.
We wish that you will contribute and learn from this forum.
Before we proceed to your question,here are few general tips to get the maximum out of this forum.
a) Please make your question as detailed as possible, more details you give the better answer you will get.
b) Avoid writing in CAPS as that is considered as shouting in this forum.
c) If any suggestion given by the member actually satisfies you, or does not solve your problem, keep that posted.
d) The members of this forum try their best to solve the problems and do have a very good command on the subject.
e) You will be surprised to see the amount of info, archives hold here..so do a search on here or at Mr Google, and in case you don't get anything you are welcome to post your query.
f) Ask one question at a time.
g) Do not use rude remarks and country/religion/ethnic background/poiltical innuendos, in your comments.
Cheers.
He must be very ignorant as he answers all the questions he is asked. Voltaire
Register to Reply 3 comments
chaterpilar (1); Current Maarey (1); rpsamel (1)
