Previous in Forum: OPERATING MANUAL FOR ENTEKIRD MODEL 246 BALANCING INSTRUMENT   Next in Forum: Appropriate calculation method for Heat Input
FORMULA TO CALCULATE
11/11/2008 9:21 AM
Dear Friends, I'm new to QC World.
I was assigned to conduct Procedure Qualification Test as detailed
6" sch 80 x processes - Root+hot passes -GTAW, Fill + Cap - SMAW
I need to know formula to calculate
a) Deposited weld metal thickness / volume
b) Gas Flow rate
c) Travel Speed and Heat In-put
Pathfinder Tags: quality
Good Answers: 53
Re: FORMULA TO CALCULATE
11/11/2008 9:35 AM
Which industries? what process is? every one may not be able to understand your abbreviations.
I believe that most of the CR4 members replies most of the questions on the basis of their wisdom and common sense, Not that they belongs to the fields to which question belongs to.
11/11/2008 9:57 AM
Rakesh.
I'm working in Marine Industry involved in Offshore Industry
GTAW - Gas Tungsten Arc Welding Process
SMAW - Shield Metal Arc Welding
Hope some one familiar with Welder Qualification or Welding Procedure Qualification Tests, maybe a welding engineer.If someone has, pls send welding parameters calculation formula handbook.
Thanks
11/11/2008 9:23 PM
11/11/2008 9:29 PM
11/11/2008 9:08 PM
Please see my responses/links on this thread:
http://cr4.globalspec.com/thread/29181/welding
Anonymous Poster (3); Gane (1); rakesh_semwal (1)
