Previous in Forum: Re-Bar Requirement   Next in Forum: Ozone as a Disinfectant in Water Filtration
scaffolding
11/11/2008 9:42 AM
For repainting of a building, scaffolds were required. the scaffolding contractor build a scaffold to the west direction of the building and this scaffold was inspected and certified for use. the contractor decided to start erecting the scaffold in the north direction and tie it to the existing completed scaffold while workers are on them. is this an acceptable practice and is their any breaches to any of international standards?
Pathfinder Tags: scaffolding
United States - Member - Charter Member Engineering Fields - Instrumentation Engineering - Charter Member
Good Answers: 73
Re: scaffolding
11/11/2008 10:36 AM
Try here for laws, (in the US), and general safety practices for scaffolding:
http://www.osha.gov/SLTC/scaffolding/index.html
I go into every human encounter expecting to be framed for a crime I didn't commit. Dilbert, 2013
Re: scaffolding
11/11/2008 11:59 PM
General rules for scaffolding - requires that a freestanding scaffold can be erected at a 1 to 3 ratio. (example: 5' wide equals 15' high). To achieve greater heights the scaffold must be attached or anchored to the structure. Another method of increasing scaffold height would be to use outriggers or extenders. (1 to 3 ratio still applies).
Now to answer your question...It is acceptable to tie into or anchor to the existing scaffold as support when changing direction. This enables the workers to walk from the West elevation to the North elevation in a continuous and safe manner.
Check to see that all scaffold or outrigger bases are on solid ground or that base plates have been installed. In addition to the above requirements scaffolds must be installed horizontally level and with the proper use of cross braces, guard rails, pig tail pins and decks or planks.
Good luck with your project!
Canada - Member -
Re: scaffolding
11/12/2008 10:12 AM
I think his question was could they be attaching the new scaffold to the existing one while the workers are on it. Not something I would recommend. Scaffolds are safe once all the pieces of the puzzles are in place. If something happened to the scaffold being erected before it is completed, it would entrain (push/pull) on the existing scaffold and possibly put the workers out of balance (risk of injury). Unless the existing scaffold is safely anchored to the building, I would not climb on the scaffold while they are tying into it.
Handle every stressful situation like a dog. If you can't eat it or play with it, just pee on it and walk away. - unknown.
Re: scaffolding
11/22/2008 3:21 AM
exactly this is my question. Many thanks for clarifying my question and for your answer.
Canada - Member -
Re: scaffolding
11/24/2008 7:06 AM
You're very welcome. Be safe...
Good Answers: 25
Re: scaffolding
11/12/2008 8:23 AM
Look at the multistory Chinese scaffolds made of bamboo.
International Standards? "We don't need no stinking International Standards!"
Goodness has nothing to do with it.
Register to Reply 6 comments
beriberi (1); Bricktop (1); MiCar (1); mohfar (1); Rick@cae (2)
You might be interested in: Scaffolding, Packaging Machines, Platforms and Walkways
