Previous in Forum: Fire Extiguishing Systems   Next in Forum: Resonance Filters
Calculating Thickness of Blind Flange
11/12/2008 2:11 PM
flange reating is 3000#
pressure is 34.25bar
flange size is 36"
Re: how to calculate thickness of blind flange
11/12/2008 2:29 PM
First you confirm a couple things -
  1. What is a 3000# flange? What code/standard is that? Do you mean 300#?
  2. What temperature?
Good Answers: 101
11/12/2008 6:55 PM
3000# flange is rated for 3000psi
11/12/2008 7:53 PM
That would be the intuitive answer, but I have never heard of a 36" - 3000 psi flange.
So here's the easy solution -
Don't calculate the thickness of the blind flange - refer to the appropriate standard (perhaps ASME B16.47) and buy an off-the-shelf rated blind.
Good Answers: 101
11/12/2008 8:02 PM
agreed
Re: Calculating Thickness of Blind Flange
11/13/2008 4:06 PM
Revise your numbers. Do not look right. 3000# flange , 34.5 Bar pressure with 36 inch dia are unheard of.
Do they have in Bangla Desh?
Nadeem
11132008
May God keep y'all in his blessings Nadeem Butt
Anonymous Poster (2); Nadeem0430 (1); RVZ717 (2)
