Does anyone know of a way to signal the presence of pressure in a hydraulic line in the range of 30K PSI? It has to plumb into a hydraulic line, and have no other air or hydro connections. I need info on something other than a pressure transmitter, and that does not involve a PLC. Actually, I could use a PT if it was not controlled by a PLC. Or something limits pressure where I could use a pressure switch in conjunction with that component? I need a way to switch on safety warning lights when pressure reaches X PSI, lets say 100 for the sake of discussion. The item has to plumb into a hydraulic line. The hydraulic pressure unit does not have any electrical power to it, and HSE doesn't want something is switched manually. It has to be automated and controlled by the hydraulic fluid and the presence of pressure. If you can help thanks...
