Previous in Forum: Formula for in horizontal milling   Next in Forum: Air-conditioning
extraction steam turbine
11/16/2008 12:52 AM
how can i calculate the efficiency of 1stage extraction steam turbine.
inlet press:50 bar,inlet tem:400c
Re: extraction steam turbine
11/16/2008 2:06 AM
Calculate the theoretical maximum by flowrate and enthalpy data at inlet and outlet.
Divide the measured horsepower of unit by this number.
11/16/2008 4:02 AM
You could play around with this free software - you will have to guess at an efficiency and narrow it down to get your know proper flow conditions.
http://www.katmarsoftware.com/turbine.htm
11/17/2008 10:57 AM
If you have a one stage turbine it is more likely a back pressure machine. Extraction flow is arrived by throttling steam downstream of the entrance with a second set of valves.
Keep in mind that any calculations you make are only as valid as the instrumentation. The installed instrumentation on older equipment is usually inaccurate, new installations are suspect.
If you fail to follow through, you will fail.
