Around 80% of the entire costs are defined in the
early planning phase of an industrial plant construction project, the
so-called Front End Engineering & Design (FEED) phase. Decisions
that are made at the start of this FEED phase influence subsequent
design tasks and largely determine the usability, performance and
cost-effectiveness of a plant or unit. These in turn have a direct
effect on the safety and environmental compatibility of the plant or
unit in subsequent operation.
The FEED phase is divided into three task areas when setting up a new plant or unit:
Provisional decision on investment by the owner or investor for the construction of a unit or plant
Production of quotations by an EPC contractor
Early phase of the Basic Engineering after the order has been awarded.
The
provisional decision on investment is based on a process and
conceptional technical draft that is controlled as a rule by the
operator of the plant or unit or the licensor of the technology or
process. Here the procedure is designed and simulated. The aim is a
first cost estimate (± 25 %) and the description of the plant or unit
in the form of process specifications, including the process flowcharts
and installation planning as applicable so as to estimate the amount of
space required for the unit or plant. The estimate of costs in this
phase is often based on data from existing plants or units from which
the corresponding estimates can be made. If this is relevant in
business terms, the quotation phase now starts for the project. The
conceptional draft in elaborated in the quotation and a search is made
for a solution that is determined by the requirements and limitations
of the process, the overall constructional conditions and other project
specifications.
The most important things to be done in this phase
consist of a calculation of costs (± 10 %)‚ determined by the
provisional design of all the supply items. These form the basis for
the binding cost proposal of the EPC contractor and serve as a template
for the Basic Engineering.
Once the final decision on investment has been made
in the early Basic Engineering phase, the concepts and details in the
quotation are investigated and stipulated in detail by an EPC
contractor and all the main supply items are specified and stated. In
addition, the calculation of costs that has been made is checked
continuously and modified if necessary.
