Previous in Forum: Portable Dual Headphone Dist. Amp   Next in Forum: PCU for SCADA communication
CPUs
11/18/2008 8:53 AM
How do Central Processing Units work?
Help would be appreciated
Ross McDonald
Sincerely Ross William Bill McDonald
Pathfinder Tags: CPU
Re: CPUs
11/18/2008 9:40 AM
I have several books written about this topic, I had to read and understand them to learn how a CPU works.
I don't think I could condense all that information into one or two paragraphs.
Try reading a good book.
Nigeria - Member -  Member
Re: CPUs
11/19/2008 4:48 PM
I agree with you and add that RossMcDonald may start from here http://www.hardwaresecrets.com/article/209
Cheers,
ethobil
Join us to make the world a better place: Propergate peace.
Good Answers: 73
Re: CPUs
12/05/2008 8:15 AM
In a nut shell, they are very fast dedicated logic gates which perform basic functions such a adding, subtracting (by inverting and adding 1 - in binary), and bit shifting or comparing as directed by a set of instructions commonly referred to as machine language or assembler code.
The architecture if those kinds of basic logic structures defines what the CPU can do and how fast they can perform the instructions. Many CPU's also have timers and counters and other types of ports for specific data manipulation. They all have some sort of permanent or semi-permanate memory set aside for storing programmed instructions. They also have RAM memory for Data. They typically have both a data bus (the highway on which data is passed around from device to device) and an address bus which selects which memory cells are to be activated for accessing data.
Adding devices and software makes the system unique. Obviously, there are endless combinations of both which make up a larger device that we think of as a computer.
Register to Reply 3 comments
ethobil (1); Frank787 (1); NotUrOrdinaryJoe (1)
You might be interested in: Materials Processing Services, Processing Services
