Previous in Forum: Pressure Transmitter Working principle   Next in Forum: Boil Drum - Level Transmitter Range
Control Valve Question
11/20/2008 2:19 AM
what mean by car seal close/open into drawing of control valve?
it is just writte down below to the symbol of control valve into the piping @ instrumentation diagram.
please send me e-mail answer on my e-mail id,ok................
Re: control valve
11/20/2008 3:49 AM
Its for additional safety mostly used on the safety valve side so that no 1 accidentaly opens or close the path
Regards
Jose John
Re: Control Valve Question
11/20/2008 5:28 PM
That's right, it is for safety (or environmental) - ensuring a valve stays open or closed without someone "accidently" operating it without following proper written procedures/instructions, signatures, etc.
A "car-seal" is either a plastic or metal band that locks onto itself when the ends are connected - much like a tye-wrap or zap-strap. It has to be cut off in order to operate the valve.
11/21/2008 2:09 AM
The term "car seal" comes from the railway industry when the doors of rail cars were sealed with a tamperproof device like the ones described in post 2. It is used on valves that should remain in a open or closed position during normal operation, and operated only in times of emergency or maintenance. The seal has to be broken which then means that authorisation to break the seal has to be formally requested, or a report must be submitted after the seal is broken.
I am suprised to see it indicated in connection with a contol valve, unless it is a manually operated control valve, as automated control valves would, by definition, need to operate continuously.
11/21/2008 5:57 AM
Hi all,
Sorry but, car seal in a control valve??? How will the valve control if it is car seal close or open?
Regards
Ernesto
11/21/2008 11:58 PM
Good Thinking
11/21/2008 8:59 AM
just a thought, might it mean the control valve needs a supervisory command to operate rather than an actual physical "car-seal"
11/22/2008 12:03 PM
Hi,
May be that "car seal" a control valve.Is when the air supply to the valve is closed so that the valve fails open or close, then a "car seal" is place on the the air supply valve to prevent the valve from being open or close with out someone's permission. We not only close the air supply and lock it out but actually disconnect the air supply and tag it out to prevent the valve from opening(fail close valve)..Thank you
"The older I get -The better I was"
Register to Reply 7 comments
Anonymous Poster (2); ernesto1962 (1); Garyvan (1); josej (2); wrenchpuller (1)
