Previous in Forum: Device for Connecting Two 110 VAC to Make One 220 VAC   Next in Forum: O/L Relays
Identifying Two-Speed Motors
11/20/2008 8:04 AM
I have two speed motor in our company,but motor terminal 6 no's
Approx Value
1.1440 rpm, 7.5 kw
2.750 rpm, 3 kw
How to identify 7.5 kw,& 3 kw
Spain - Member - New Member Engineering Fields - Nuclear Engineering - New Member
Good Answers: 25
Re: Identifying Two-Speed Motors
11/21/2008 5:45 AM
Hi saransat1981,
I suppose you are taking about 50 Hz, 2 pole motor (3000 rpm synchronous speed, if asynchronous, can be 2750 rpm due to slip) and 4 pole ones (1500 rpm synchronous and maybe 1440? rpm asynchronous).
Obviously the motors shouldn't have nameplates. If both types are fed at the same voltage, at full load just measure the current with a clamp-on ammeter.
Kind regards
Belgium - Member - New Member
Good Answers: 21
11/21/2008 12:14 PM
You have a 4 / 8 pole motor.
The higher speed (1440 RPM) leads are normally identified with 2U, 2V and 2W
The lower speed (750 RPM) leads are normally identified with 1U, 1V and 1W.
Is theire a someting like "D / YY" indicated on the motor ?
Register to Reply 2 comments
You might be interested in: DC Motors, Terminal Blocks, Stepper Motors
